I follow all the advise from this forum how to connect the mute swich to my preamp, output connect it to ground.
Yes it works. I used DPDT switch then connect 0.1µF between the pins (input to output pins) and not the input to ground. But there was thump sound on both mute off and mute on...
Any advise how to deal with this????
Thanks a lot..
Billy
Thanks a lot..
Billy
Thanks a lot... It works but still have a thump sound every time I mute on but @ off pretty quiet.
Regards...
Regards...
What you describe suggests that there could be DC on the mute switch. When the switch is activated, it causes the capacitor to discharge suddenly, giving a transient that you hear as a 'thump' in the speaker. When it is deactivated again, the capacitor charges again but slowly, through a high value resistor.
Thanks guys...
I have a 1Meg resistor connected to GND after the ouput cap of 0.47µF/600V.
What value needed for this resistor to avoid the thump sound?
Thanks,
Billy
Thanks,
Billy
If I may say so: if you make a habit out of muting the preamp while it's warming up it's impossible for a DC voltage to develop at the output of the coupling cap.
It's shorted to ground so whatever the bleeder resistor's value, nothing can happen at that spot.
However, in case you measure a DC voltage after a period of warm up at the coupling cap and it doesn't go away, you have either DC coming in from the amp or a leaking coupling capacitor.
Either of which could be the cause of the turn-on/turn of thump you're hearing.
Cheers,😉
Cheers,😉
- Tubes / Valves
- Help on Preamp Mute Switch
