I built the circuit at page 29 of PCM2706 datasheet:
focus.ti.com/lit/ds/symlink/pcm2707.pdf
It doesn't work. When I connect the USB cable to PC (Windows XP) it says "UNKNOWN DEVICE".
I also notice that the 12 MHz crystal oscillator doesn't work (I use CMAC HC49 12.000).
I don't know what to do.
Thanks for your help
Have you pulled the suspend pin high, if not the circuit will not start up. Also check the circuit arround the clock oscillator to make sure it has not got any shorts and is wired correctly the oscillator should start even if the part is not running correctly. Also check the power supply is good and is getting to all the power pins.
Regards,
Andrew
Regards,
Andrew
See my own PCM2607 design here
I think that the PCM2606 has to have a programmed serial EEPROM connected to it, containing the USB identification data. The PCM2607 does not.
Check the chip is generating 3.3v on the VDD pin. Note how the USB D+ line needs to be pulled up with this 3.3v. I am assuming you are using bus-powered here.
edit: Hey, I just noticed I didn't pull *SSPND high! Whoops, oh well, my circuit still works.... it is probably internally pulled up.
- Digital Source
- Help needed with PCM2706
