First tube seems like my A405 and B406 Miniwatt
DSCN0131_s | Flickr - Photo Sharing!
6L6.
My picture is of a 6BG6, a 6L6 variant, but has the same plate structure.
Most rectifiers use pins 4 and 6 for anode pinouts.
Pins 2 and 7 should be filament.
Be assured, it is not a recitfier. It's a power pentode of some kind. More then likely a 6L6G as Kevin said. Whoever told you it was a rectifier was wrong. If it did come from a power supply, it was used as a series pass tube as 6L6's often were. And the "dag" coating on the inside of the glass was common on the older 6L6Gs. I have never seen a rectifier tube with an internal dag coating.... i was told that its a rectifier tube, im building a tube power supply, so i need to be sure.
- Tubes / Valves
- Help needed on identifing tube
