Howzit
I am about to go ahead with my DIY project, which will basically be to align 12 Pyle PLG15 subs in dipole enclosures.
They will be driven by a Behringer Europower 2500 amplifier, I still need to check what EQ I will be getting but I am also purchasing the Behringer Feedback Destroyer.
I'm not an audio professional ( 😡 ), so I need some help in some calculations for the sound these will be producing.
Take room size as approximately 6m in length, 6m in width and 2.75m in height.
I would like to know approximately what Hz and SPL these subs as a unit will be able to put out 🙂
If any more information is needed then please just ask!!
Cheers in advance
JohnnyJ
Cheers in advance
JohnnyJ
Hi
Dipole subwoofers need good amount of X-max , which is not the case with these pyle drivers. Moreover these drivers are ment more towards car audio rather than home. With a 38Hz Fs they will not produce good deep bass inside your room. These drivers relly on cabin gain to reproduce deep bass inside a car.
For any calculation help please post the TS parameters.
Rgds
Sumit
Rgds
Sumit
Fs on the Pyle PLG-15 is ~26.4hz.
Qts .73. 24mm xmax, but Im pretty sure thats peak-peak.
Given the price, why is this a bad dipole driver?
Pyle PLG series.
The Feedback Destroyer is an eq.
Pyle PLG series.
They are rated at 90 dB at 2.83V.
You have 12 drivers so about 100 dB at 2.83V.
I assume you will wire them to get around 4 ohms, I get 5.33 ohms here, you could also wire them to get a 3 ohms load...
So you have 1800W to work with.
You'll get 130+ dB in the midbass.
I guess you will get around 110+ dB at 20 Hz?
Fs of 26 Hz is ok.
refer -- http://www.diysubwoofers.org/dipole/design.htm
-- http://www.linkwitzlab.com/woofer.htm
for your design requirements.
Going with U-frame dipoles as per the NaO system should help you go low. 14" high by 21"-24" long per cabinet. 35.5cm high * 53-61cm long. These are the internal dimensions.
- Subwoofers
- Help needed in calculations please
