help needed for F5T transformer
I am preparing to build a F5T amp based on the guides in the forum.
See that a stereo F-5T v2 requires a bipolar power supply of (+/- 32V). This will require an 24V+24V (or 48V Center Tapped) transformer from 600-800VA, and PSU capacitance of 80,000uF per rail or more.
Unfortunately the Antek AN-6224 is out of stock at the moment.
What other good options do I have?
Hi Hiraki,
Thank you but wasn't sure how i could tune down the extra voltage.
You don't need to tune down the extra voltage. The F5T has a cascode circuit for the input jfets so you can actually even go with higher voltage, taking into account the amount of heatsink necessary.
Most power supplies drop about 2-3 volts when you bias the amplifier into class A.
My F4 power supply has 33V rails when unloaded and it drops to about 30.5 when biased (about 2.8 A per channel)
There is cascode in F5T v3. But even for v2, I would not worry about the 1VAC difference.
And if you do find the voltage under load to be higher than you like, you can always
increase the R in the CRC power supply a little to burn some voltage (and lower ripple
at the same time.)
I would pay attention to the Idss of the jfet to make sure their thermal dissipation isn't
too high.
Dennis
How are you getting 2.8A per channel? monoblocks?
My f5 with 31V rails can only get to about 1.8 or 1.9A bias per channel in the 5U chassis. Heatsink temps are 55C, sometimes more if it's a hot day.
at the same time.)
too high.
Dennis
My F5T (no cascode) with 31-ish volt rails and 8ma jfets results in 43C case temps on the jfets. I have little push-on sinks on them. Nothing to worry about I think.
I have about .45-.47 A on each of the 6 output transistors, in a 5U dissipante case. The hottest spot in the sinks on a hot summer day is about 57-59º. My f4 is built without the input jfets as it is driven by a BA3 front end.
.47*30,5V*6= about 86W dissipated in each channel.
