Help needed determining which reverb tank for an amp.
Hey everyone. Here's my dilema. I have a 1973 Earth Sound Research Revival 410 tube amp I'm restoring. Model number M1954. All my "research" says this amp was a direct rip off of the second phase of the 1970's "Peavey Vintage" series amps. There were two versions of the Peavey Vinage, and like the Earth Sound Research amp I'm working on, the second phase Peavey Vintage had a solid state preamp like the Earth Sound Research amp I'm working on. (In other words this is NOT not the Peavey Vintage with that bizarre internally mounted dual tube preamp.)
This amp I'm working on has four 6L6 only, with a solid state pre amp. I've looked at a chassis photo of the said solid state preamp Peavey Vintage and but for minor differences on the big capacitors by the transformers, indeed they appear to be identicle.
Everything works great on the Earth Sound amp as is but for one problem; someone had swapped out the original reverb tank with an unsuitable unit. This is blatantly obvious for two reasons.
One, the reverb barely works at all as is with the tank I got it with; it's barely audable. Two, the tank thats in it has a retail price tag sticker on it from some defunct old electronics supply store in Michigan, so it was definitely replaced. It was absolutly put in second hand. The tank thats in it is an Accutronics 8BB3C1B. Its gotta be way off spec for this amp. Here's why I say that:
I pulled the long spring reverb out of my Peavey Delta Blues amp just to give it a short trial run in the Earth Sound. It's an Accutronics 4EB2C1B. Immediately the Earth Sound reverb came alive, and the reverb worked well. At least tenfold better than the tank I got it with. Yet it's still not what I'm looking for. I want more of a Fender Twin kinda reverb, deep and thick. I'm considering an Accutronics type 9 three springer...
* Problem being; how do I determine what the proper input and output impedances for this amp should be, when the original tank is long gone? I have the schematic for the amp, but it doesn't tell me anything as to impedances for the reverb circuit, or which jack is the input and which is the output. And if it does, I'm not near knowledgeable enough to know how to tell from a schematic print.
Now when I reversed the leads on the reverb tank using either the tank it came with, or the Delta Blues tank, it sounded exactly the same; no difference at all either way. From all I've reading uHey everyone. Here's my dilema. I have a 1973 Earth Sound Research Revival 410 tube amp I'm restoring. Model number M1954. All my "research" says this amp was a direct rip off of the second phase of the 1970's "Peavey Vintage" series amps. There were two versions of the Peavey Vinage, and like the Earth Sound Research amp I'm working on, the second phase Peavey Vintage had a solid state preamp exactly like the Earth Sound Research amp I'm working on. (In other words this is NOT not the Peavey Vintage with that bizarre internally mounted dual tube preamp.)
This amp I'm working on has four 6L6 only, with a solid state pre amp. I've looked at a photo of the said Peavey Vintage and but for minor differences on the big capacitors by the transformers, indeed they appear to be identicle.
One, the reverb barely works at all as is with the tank I got it with; it's barely audable. Two, the tank thats in it has a retail price sticker on it from some defunct old electronics supply store in Michigan, so it was definitely replaced. It was absolutly put in second hand. The tank thats in it is an Accutronics BB3C1B. Its gotta be way off spec for this amp. Here's why I say that:
Now when I reversed the leads on the reverb tank using either the tank it came with, or the Delta Blues tank, it sounded exactly the same; no difference at all either way. From all I've read online, thats not altogether normal either. So uh, say huh? Shouldn't this make a big difference? Because it doesn't sound any different to my ears....or three of my guitar player friends who were here with me.
* That said:
A) How do I determine what impedances tank to order?
B) How can I determine which is the input and which is the output on the amp....when it's not labled on the chassis?
I did note that one jack has a single wire going to the center conductor inside, and the other jack has a shielded cable soldered on to it, but the sheild wire is not connected at the circuit board end if this is any help.
Common sense dictates the impedance of the above Peavey Delta Blues tank is a much closer match to what the amp needs, simply because it works and functions. It's also notable to add that it sounds strikingly the same when installed in the Earth Sound amp as it does installed in the Delta Blues its actually for. In either amp the reverb is clearly there, but by no means as lush or deep as I'd like it to be in either amp. That being said, I'm guessing its close to being the right impedance for the Earth Sound amp simply because it sounds close to the same as when its in the amp its for.
But "close to right" isn't my objective. One hundred percent correct or close as I can get to spec is my objective is. So again:
A) How can I determine what input and output reverb tank impedances to order for it when the original reverb tank is missing?
B) How do I determine which is the input and which is the output on the amp when the chassis is not labeled?
C) Why does it sound the same no matter which way the leads are connected? Is that normal?
Any help would be greatly appreciated. Thanks much.
Thegtrzan
Thanks much Enzo. I replied on the other forum. Very much appreciated and I will take your advice and just buy another 4EB2C1B for it seeing as how it worked well. I don't need it to be a surf verb, just was hoping for a little better, but it is what it ain't! I forgot that the Twin Reverb sound is a tube driven reverb. No worries on that schematic, its not there in my files for me, its there in case I have to take it somewhere. I would never attempt to work on it beyond the cabinet and speakers etc.. My dad was a tech back in the day. He never taught me how to work on tube amps, but he did instill the common sense to know enough to know when I'm stepping in it! Wish I knew more, but I'mjust a musician and school teacher who does a little carpentey and fix it stuff as a hobby. No worries, I won't barbeque myself or attempt to work on it otherwise. Thanks again.
The critical difference between the two units you mention is the input impedance; the "poor" one is 150 Ω; the Delta is 600 Ω---which is why it works better. You'll probably be happier with a 3-spring unit than the 2-spring unit---use a "9" series instead of the "4" series.
