Help Need Help Ballast
Ok here is the Deal. I bought a Proxima DP5600 off ebay for a Really good price of 60 bucks, he told me that the Bulb was bad, Ok no problem i will find another one and Replace it, well the Bulb is not the Problem, The Ballast is. It will try to Start the Bulb but all i get is a Hissing Sound. Most likly a Cap going out or out, Ok i have 2 Options that i can Choose,
1: Buy a Pulse Start Ballast for a 250W Metal Halide Bulb for 60 Bucks and rig ( ****** :cop: racist text censored by moderator team) ( Sorry DIY LOLOL) something on the Out side of the Projector to Hold the Bulb.
2: Find a Cheap Ballast for a Proxima and try to wire it in.
Well i when for the 2nd one, Wrong Move.
Here is the Problem now. I got a 150W Ballast off ebay for a Proxima DX2, for 9 Bucks and Working. I cant Figure this wiring out.
There is 2 Pices to this and 3 Computer Boards.
1 the Main power input that must Reduce the Voltag or something
2 this board has 1 Connector with about 12 pins that must go to the Main board to Supply Power to Operate the Board
3 the Board that has the Ballast on it that Drives the Bulb.
Ok on the 3rd Board there is 5 Wires, Pretty Simple Right , Wrong.
There is 2 Big ones, Brown and Blue, One is marked + the Other is marked -, The problem with these is that i dont no what the Voltage and if it is DC or AC, I dont see any Bridge Diodes in this system to Change the AC to DC.
There is 3 other Wires in a Connector also Brown, Red, Black, These are about 16-18G wires Pretty small.
I just need a Diagram or Something to Figure out how to Hook this Ballast up to my DP5600. Or how i can use this to Make a Power Supply for a 120W or 150W Bulb, Witch i have both of these the 120W is a UHP and woudl rather use it instead of the 150W or 250W.
Or if anyone noes what is wrong with the Stock 250W board or even a Diagram for it that would be great
Here is some of the Numbers off everthing
Main Unit Proxima DP5600
Main Unit Power Board has a Few Numbers
MCL-3-67, or JC1-DIS, or 1AA4B10C0930A
ok on the new power supply here are the Numbers on it
Ballast Board
TD-T52V, or LC904-4001A, or 94V-0, or PHG151G8 or on the HV out put there is LC904-9001 and 23VOZK
There is the manufactur name Acer on the Boards as Well.
SORRY for the Long Message but i like to get all the Info srtight and there is no Questions.
Please Email me At Ccoutts@ev1.net if you have some info
I am Going to go Crazy i got Resident Evil 2 on my computer and want to watch it for the Frist it on my own screen .
:att'n: Guys, racisim and hard language are not aceptible in this forum, please refrain yourself from doing so.:att'n:
:att'n: SAFTEY WARNING!!!!! :att'n:
Projector ballasts must be of the right spec for the given bulb used. Failure to do so may contain a serious voltage and fire threat to human life.
This operation should only be carried out buy a fully trained personel!!!
Trev:cop:
Sorry about that. :xeye:
I have took Many classes on HV Electrical Systems. I right now have a 800,000Volt Teslia Coil in my garage. This Bad boy would kill very fast.
Is there any DIY Ballast's or Anything that could help me.
I am thinking about go out and Buying me A Pulse Start Ballast for the Wholesale supply store. But would like to get this working so i dont have to spend more money.
