Help me what can really be the problem for the fan not working on my QSC K10 speaker but it's able to play sound only the fan
It's possible it is something other than the fan, and the fan is only a symptom. There could be many reasons, you would have to help us.
But is it that bad or I just concentrate using it just as it is?It's possible it is something other than the fan, and the fan is only a symptom. There could be many reasons, you would have to help us.
Alright thanks so much for your advice noted with ThanksYou can easily burn it
That fan is not decorative.
How do you know fan is not working?
QSC claims it´s a "very low noise fan"
Also: fans are not always ON, many are temperature controlled and if amp is cold, as in used at home or very low volume, it might never turn on.
Is it new?
Does warranty still hold?
If so, rather than asking at a Forum, ask seller or straight call QSC
In any case, you know the drill:"no User serviceable parts inside"
Is it new?
I thought you meant that since the fan stopped, there is no sound.but it's able to play sound only the fan
- General Interest
- Everything Else
- Help me with QSC K10 speaker fan not working
