Help me please.....
I want to build a DAC does it have USB,Optical and
Coaxcial inputs and I have specify list of IC does I use.
That is
-CS8416(For Optical input)
-PCM2707(For USB input and I2S output)
-PCM1792
Can someone build me a schematic(I/V stage and power supply stage too.)
Thanks.😀
Probably the best thing to do is find the datasheets for these chips. Datasheets often have suggested circuits that you can use.
I think the trickiest bit will be switching the I2S.
Once you've some ideas for a circuit, post them here and ask for help and feedback.
If you're not sure how to design a PSU, maybe you should consider buying one - mains electricity is dangerous!:hot:
