YST MSW10
I have one of these which shuts down after about 5 minutes. I am a total beginner on electronics so maybe I could start with this, since it does work, and very well, but briefly. Help??
I believe the problem is something might have shorted out inside and it is causing it to shut down. I recommend looking at the circuit board and look for any dark spots or buzzing coming from within. If you know how to use a multimeter then check any transistors or capacitors to see if you get conductivity or resistance. Other than that I can't think of anything else. The subwoofer has and option to shut itself off if it does not receive a signal so you might want to start there, make sure the input is receiving a signal and turn the switch in the back to off. Let me know on your progress.😎
Thanks for the quick response. It shut down while getting input so I'll just see what I can see. Thanks
In need of schematic please
Hi this is a long shot as its an old thread, does anyone have the schematic for Yamaha yst-w 015 subwoofer. Please mail me icread37@hotmail.co.uk
Thanks ir
Thanks ir
