B bigmike216 Member Joined 2004 2005-06-08 7:42 am #1 2005-06-08 7:42 am #1 I'm going to be in need of 6 transformers with dual 22ish volt secondaries (or 44ish CT), around 120va... Does anyone know of any surplus or relatively inexpensive transformers? These will be going inside powered monitors. 🙂
B bigmike216 Member Joined 2004 2005-06-09 11:32 pm #2 2005-06-09 11:32 pm #2 bit of a brain fart there, I need 4, not six 🙂
cowanrg Member Joined 2002 cowanrg.mesanetworks.net/projects/ 2005-06-10 5:20 pm #3 2005-06-10 5:20 pm #3 apexjr.com has one listed thats 28v secondaries, 150va for $22 each. http://www.apexjr.com/miscellaneous.html partsexpress has one brand new thats 22v secondaries, 160va for $38 each. if you can handle 28v secondaries, the one at apexjr would be a good choice.
