Help Me Clone this Radical Speaker
Hi All,
I wanted to make a DIY clone of this speaker http://www.wolcottaudio.com/WA_omni.htm
and I was thinking of making it a stuffed U-frame Dipole/T-Line. My questions are
(1)when does a U-frame Dipole become a T-line (2) What are the BSC rules for such a weird Speaker
(3)Will four GR Research M165-X's with a Morel MDT33 give me 92db@8 ohms and go down to about 30hz?
(4) Would a sealed bass section be better?
(5)Could a !st Order series XO work here?
Thanks Ben
What they basically do is putting a tweeter between two closely spaced waveguide elements instead of using a reflector in order to get better vertical dispersion, not so different from what Mirage do. But from the simple spherical shape of the waveguide I would expect horn colorations. In my opinion the pyramid-setup of four midwoofers only slightly improves the vertical radiation pattern compared to a traditional one midwoofer plus reflector setup, but on the other hand causes lobing problems. So in my eyes it is a radical radiation pattern über alles concept.
If you really want to clone it, my advice is using a car tweeter with no front plate and four Eighteensound 6ND430 midwoofers (16 Ohm version) in parallel.
http://www.eighteensound.it/index.aspx?mainMenu=view_product&pid=243
As you can see it has a very nice response 45° off axis and should be OK for the pyramid setup.
