Hi! I want to put myself a linear actuator on the sliding gate to the cottage. I looked in the internet, there are a lot of offers and the prices are very different. Maybe there are people here who understand this and can advise me what type of actuator is better, manufacturer and where to buy? I will be very grateful.
Are you looking for something like this?
dc 12v 200n 50-300mm stroke tubular motor linear actuator motor Sale - Banggood.com
Need to know the max force and stroke length. Presumable you want one thats IP rated for outdoors (IP67 or better)?
With a gate actuator you have to consider safety, ie don't make a death-trap.
Hi! Thank you all! Gate weight 150 kg. Gate width 3.4 m.
I choose between Electric Linear Actuators for High Temperature, Long Linear Motion, Group 42 Actuators and Linear Actuator | PA-03 Model by ActuatorZone
I've heard of people adapting garage door openers to operate gates. Here's one...
YouTube
Yes, I saw this example, but I need something like an all-in-one with a remote controller. Any ideas?
I think this is what you are looking for: https://www.amazon.com/CO-Z-Automat...ocphy=9032039&hvtargid=pla-393985408075&psc=1
Usually once I find the right search term I can find a number of options. Good luck.
I've been using stuff from CAME / BPT and the sliding gate was installed 20 years ago and is working fine. Well it needed a new board a couple of years ago, but the board is fine. It was a bad relay and I repaired it since they aren't cheap (60-80€).
I have a sliding gate, two swing gates & 2 garage doors at home.
All came in complete kits and were installed by me, except the supports on the gates in which I've asked for help in welding, but I've could have bolted them.
There is a distributor nearby and I can get a 40% price discount.
Also the older one was about 500€, but the newer ones You get now for half the price.
Beware of the cheap ones from hardware / construction stores. Ask for spare parts out of warranty.
Gate Automation | CAME UK
- Design & Build
- Equipment & Tools
- Help me choose a linear actuator
