Help me calculator OPT for 807, 6C4C tubes.
Sorry for my English.
This is my Fe:
invalid said:
Thanks very much. If I want change values Zin to 3100 Ohm then power is decrease. But I can use for 6C4C or 6L6 in the future, It's correct?
Yes, but consider tying the first and the last primary sections in parallel (those who have 537 turns), and then in serie with the middle one (1075 turns) the neat result will be a 1600 turns primary.
That being (2149 / 1600) = 1.34 : 1 of the original turn ratio or, squared 1.8 : 1 impedance ratio.
And 6000 / 1.8 = 3333 :D
Very near of your target !
So you obtain your dual impedance OPT ;)
Yves.
You may also imagine other primaries combinaisons
