hi everyone ...
i m so new in tubes , and i wanna try to build a tube mic preamp for recording vocals and instrument and connect it to my pc for recordin ... the only available tubes here are 12at7 and 12ax7 ...
thnx for any schematic or any help ...
If you can get 12AX7 and 12AT7, I'm sure you can get 12AU7 (ECC82) also. Have a look here: http://gyraf.dk/gy_pd/g9/g9pd.htm
It's not cheap, but it's good.
Best regards,
Mikkel C. Simonsen
Best regards,
Mikkel C. Simonsen
thnx for reply 😉
i don think i can find any input/output transformer 🙁 ...
here s lack of tubes , and i was very very happy when i finaly found these 12at7 and 12ax7 used tubes in very old repair stores ! i don think i ll find any other tubes in here , so plz can u help me w these tubes ? i just have 2 12at7 and one 12ax7 !!!
http://geek.scorpiorising.ca/MicPreamp.html
You can make a fine totem-output with a 12AT7 instead of 6N1P. Just don't expect to be driving any 600 ohm lines 😉
SY said:Do you have availability of transformers? That will help considerably!
Hello ,
you can build now your own transformers from the famous german studio amp V72 , look here :
http://www.irt.de/IRT/publikationen/braunbuch/V72_EUE.pdf
and here is the circuit :
http://www.irt.de/IRT/publikationen/braunbuch/V72.PDF
and here is more informatiion of this old studio amps :
http://www.irt.de/IRT/publikationen/braunbuch.htm
Enjoy this old circuits and merry christmas and a happy new year ,
Alexander .
hi and thx a lot re 604 and geek 😉
i hope i can build the geek preamp ..
and bout re 604 .. i m so new in tubes , infact i know othin bout them .. can i build input output transformers w regular parts used for power transformers ???? what exactly should i know and have ???
happpppyy newww year everyone , and have goodluck
- Tubes / Valves
- Help me build a tube MIC preamp plz
