help making some cables
Well it very much depends upon what is at the other end of that DIN cable. You are going to have to make a custom cable or have a company do that for you. But it may not be as simple as wires running from A to B. For example in many Peavey amps, there is a pin that must be grounded before the amp will even look at the footswitch signals.
Well--- we would have to know the brand of amp and what you want to control, (like boost or whatever). Also I would guess that the control outputs on the g-major are a switch closure. pehaps even a relay closure. This setup can be made to control most any kind of on/off function but somtimes it takes a bit of additional circutry, somtimes not. Get out the manual for the G major and look for the information on those switched outputs and post it. Just post the description of the controls as listed in the manual. More information :magnify:
