Help lol Bic America venturi v604
I currently have a set of Bic America venturi V604 speakers and I'm looking to replace the woofers I'm having trouble finding what would work best with the stour speakers there are 6 and a 1/2 6 Ω speaker any help finding a replacement woofers for these would be great appreciated
Any markings on the woofers? There may be a manufacturer's date code [or not considering they were made in recent decades] or if we're really lucky, a searchable part/model #.
Anyway, unless you can find its specs, then you'll have to measure their basic T/S specs to get in the 'ballpark' WRT bass performance and a frequency, impedance response plots to 'close enough' match up to the tweeter.
Most likely though, you're out of luck and short of designing a whole new speaker alignment or buy engineered kits to replace all the components/wiring in the set, then about the best you can do is find some that looks similar to yours with ~ the same ohm rating and an Fs around/at whatever the speaker's lowest bass response is.
GM
