Good day all
Could someone help be identify these codes and part numbers to match them
A6 - this is a diode
A7W - this is a diode
38W - this is a three pin sot23 case
SS14 - diode
WV4 - 3 pin sot23 case
Thanks for any assistance
SS14 - diode
Thank you for you response. Is it that the code matches the data sheets in the order that they are listed? My part had just A6 on it, is the compatible part 1s2838?
My diode is two pin which is closer to BAS 16 case style
Ice power 1000asp
Good day all
I am repairing a 1000asp module and bed some help identifying the smd codes. Please see list below
Good day all
SS14 - diode
Good day all
Good day all
SS14 - diode
It depends if your diode has 2 or 3 pins and you must identify the case used.
then, you can find the codes here :
caxapa.ru/thumbs/588912/smd-codes.pdf
For example WV4 :
BAT54S Si-diode Dual Schottky Rectifier, 30V, 200mA, Vf<1V(100mA), <5ns
For example WV4 :
