Hello Everyone,
I have a power transformer out of an RCA 6 channel HT amp and would like to use it with Brian's LM4780 kit. It has the following numbers on the top:
J2802210012X
29wp288
ks olt st
It has 3 thick wires that are red, yellow, red and four smaller wires which are Gray, Orange, White, Orange. I beleive I will connect the thre thicker wires to the power cord and then the four smaller ones to the power supply boards, but where?
Also I plan on using 3 seperate chasis, one for the transformer and power supply boards and one for each amp section. Is it ok to use heavy gauge electrical cord and plugs to "plug" the amplifier sections into the power supply section? Also should I put the power supply boards with their respective amplifier boards or keep them with the transformer?
I appologize in advance for all of the questions.
Thanks,
John
J2802210012X
29wp288
ks olt st
Thanks,
John
