The DTI should first be hooked to your transport's digital output via a 75ohm BNC or RCA connection whichever is available. The DTI's digital output is then connected to the DAC V1.1 digital input using either a 75ohm RCA (or BNC whichever is available) cable or to the I2S connection via the I2S buss cable. You need to be sure that the DacV1.1 supports I2S despite the fact that there is a facility for connecting it to an I2S cable.
