Hello, I need help from knowledgeable people - in the 21st century there was an urgent need to connect an AES / EBU signal (110 ohm - max 7 volts) to an I2S receiver (max 5 volts) ...
100 years almost all manufacturers of CD players and DACs - make such an input ... Can someone give me a good proven schematic diagram of this connection (for example used by companies such as Accuphase, Madrigal, Sony, McIntosh) ... list the necessary details?
thanks, but this is completely wrong! ... I need an AES / EBU signal (from CD transport) to be connected to the output of the I2S chip ...
and your link about converting to S / PDIF is not at all the same 🙁
