in 24 hours I have to give a n answer for a 350.5 (110 volts) here in Italy we have 220V. I have been told by Mr Vuky said is possible the convertion the seller it the States can't be done it, I do not know what to do!!!
Vuky if you are on line Help me!! or any body else!!
Many thanks
Bebo
Many thanks
Bebo
Parts and servicing - the real problem
Hi Bebo,
I understand the situation, High-end stuff is stupidly overpriced in Italy, buying overseas is quite tempting but... most of the times no one is going to help You with a grey imported amp.
The same happens if You need a replacement part.
If You really want it You may consider to use hyper sized 220 to 110 transformer, but it's not going to solve the parts/repairs side of the problem. Beware!
Hi Bebo,
