Hi guys new here,Can someone direct me to a really good high power tube amp project that is fairly cheap to build?somthing that is good with 4ohm loads and an a and b channel to run a total of 4 speakers at times.
thanks for the help in advance
Mike.😀
Mike.😀
Try a 2 channel KT88 push pull (about 100W per channel). Use output transformers that have 4, 8 & 16 ohm taps.
If you need to use 4 speakers, you can wire two pairs of speakers in series and connect to the appropriate tap, eg two 8ohm speakers in series connected to the 16 ohm tap.
alright that sounds good the kt88's are well priced too if i can rember correct?I didnt think they worked well at the higher power but cool that should get me started.Thanks
Mike.😀
Mike.😀
A push pull pair of KT88s is good for 50- 60 W. For an amp in the 100-120 W. range, you need a quad of KT88s in parallel push pull. O/P transformers that handle the power in question are always costly.
BTW, wiring 2 pairs of speakers in series is not a good idea, unless the 2 pairs are "identical".
Great suggestions so is there somewhere I can go to find some good plans to build one of these?I cant wait to get the amp going bacause my new mtm diy 4ohm speakers are nearing completion and I will need a new amp to run em thanks again
Mike.
Mike.
Mike,
Do you know what the impedance curve of your nominal 4 Ohm MTM speakers looks like? Speakers with significant dips in the impedance curve, particularly in the power hungry bass region, are poor candidates for mating with tube amps. If your MTMs were nominally 8 Ohms, connecting them to the 4 Ohm taps is way to deal with impedance dips.
100W with KT88:
http://www.triodeel.com/gec100w.gif
400W with KT88:
http://www.triodeel.com/gec400w.gif
Good luck! 🙂
400W with KT88:
Good luck! 🙂
- Tubes / Valves
- help finding a good amp project?
