HELP: F5T imaging is off-center
Didn't think much of SigJenny I'm afraid. It wouldn't work even with a Virtual Cable program installed, kept complaining there was no wave input available. Too old tech, probably worked fine with Win95 but hasn't been updated.
You can drive both channels with a common signal (music is fine) and
place any AC voltmeter across the hot outputs. If they have the same
gain then you won't read any AC. If it's only a few mV, then perhaps
that's not the problem.
Connecting a speaker to the +outputs of both channels and play a mono signal through both channels. The speaker should be dead silent, as it is going to play any differences between the two. In practice you can still have a bit of sound, but no significant output.
