Help explaining SMD Vs. Thru-hole measurements
Voltage coefficient would be the change in capacitance vs. voltage. Some ceramic caps change a lot (like 50%) others like NPO change very very little. The cap you found is .001 uF. The problem is that the NPO material makes a much larger physical cap for a given value. There are other compromises between materials you should look at but you will find much higher distortion which will show up in the output.
You can find out a lot more
http://www.avx.com/docs/techinfo/General/dielectr.pdf
http://rohmfs.rohm.com/en/products/...ower/switching_regulator/cera_cap_appli-e.pdf
The Basics & Benefits of Tantalum & Ceramic Capacitors – Passive Components Blog
These guys have an SMD 1 uF cap in a 1210 package which is quite impressive and well suited to your application. https://www.niccomp.com/resource/fi...g-Singing-NSPH-SMT-FilmCapacitors-May2015.pdf
