I tried it without speaker.
at 1kHz, the output is 1V.
at 20kHz, the output is .3V
Also, if I disconnect the ground wire from the negative tab of the OPT secondary, then at 20kHz, the output is .7V
Both LL9202AM and the Tamura F-5003 are better without the ground wire from the secondary.
there is sound coming from the LL9202AM from 2kHz to 12Khz, not the Tamura
That's interesting. Does the pitch of the sound follow your signal generator frequency or is it a constant high pitch noise?
The pitch of the sound follows the signal generator.
Sounds like that's where your HF power is going. Right you won't get arcing at 1V output but something abnormal is happening as you usually only get sound from the OPT at higher output voltages.
The effect of disconnecting the ground wire is a clue.
The precise order of connection of the primary winding is super critical. I would double check all of the connections as per the attached diagram from the spec sheet. There isn't much else to go wrong.
Connecting the primary windings in the wrong order could create inverse coupling through the capacitance between windings and could definitely manifest as sound. It would also happen only at higher frequencies.
Could you check to see whether pin 11 and 9 are labeled correctly ?
I got a feeling that the Lundahl diagram is incorrect.
I don't have anything to go on to check the datasheet, but the wiring looks correct to me.
Since the response is better without the ground wire on the OPT secondary, is it ok to not have that ground wire ?
I wouldn't let the output float. It sure sounds like some undesired coupling. Is there any DC voltage on the output side when the ground is disconnected?
Do you mean the OPT secondary ?Is there any DC voltage on the output side when the ground is disconnected?
Yes. It could provide another clue. or another thing to eliminate which is some kind of DC coupling. highly unlikely but easy to check
The response of the input stage is good.
Measured at the 75TL grid?
- Tubes / Valves
- HELP: Eimac 75TL amp high frequency roll off
