Hi everyone and sorry to pester you with dumb questions, but here goes. Thanks in advance for your help!
On the Philips data sheet at http://frank.pocnet.net/sheets/010/e/ECL82.pdf
1. Is the "supply voltage" the raw B+ or is it the voltage of the plate relative to the cathode?
2. The pentode figures imply that 9.5V peak to peak on G1 will drive the pentode section completely. Using the recommended Rk=650r for the pentode section, and 37.8mA current at the cathode, it looks like the cathode is floated 24.6V. Is this right? It looks like the cathode is going to be floated way over the grid at all points of operation. Is this right?
3. If I'm reading all this correctly, then if I use B+ =272 + Vdrop due to OPT + Vcathode, and Vpeak to peak out from triode = 9.5V, then I should be able to get 3.5wpc at 10%THD.
Sorry for the dumb questions, but I'm having trouble finding useful characteristic curves on the 6BM8 (already got the Svetlana one and it only goes down to -10V on G1). This and the RCA tube manual are the best data I've got so far and if I'm reading this right, I like this operating point better than the one in the RCA manual (only gives 1.8w output at 10% THD IIRC).
Thanks again,
Morse
Thanks again,
Morse
6BM8/ECL82
Yes, this is the voltage measured from the top of the anode resistor to ground.
2+3. Looks alright at first glance.
Cheers,😉
No such thing as a dumb question, Morse.
Cheers,😉
Frank, that's not correct actually!
"Supply Voltage" is always the voltage before the load - the raw B+. "Plate Voltage" is measured at the plate.
A 12AX7 would have a supply voltage of 300V, but an anode or plate voltage of only 150V or so.
Joel,
To clarify, some European tubemanufacturers such as Philips give an extra piece of data stated as Vb, which Philips calls "supply voltage".
I think what you mean is Va, which is measured directly at the anode.
Am I missing something too?😉
Joel,
fdegrove said:...Am I missing something too?😉
Yes. Check the "maths", and everything should fall into place.... 😉
ALRIGHT,ALRIGHT...
LOL.
O.K. So let's rephrase this:
No, it is not really the raw B+ in that it normally isn't just the filtered voltage value.
So, Vb is the anode voltage measured between the top of the anode resistor and ground.
Va is the voltage measured at the tail end of the anode resistor and ground.
In the 12AX7 example Vb = 300VDC and Va = 150VDC.
Cheers,😉
LOL.
Cheers,😉
Plate Voltage
I thought the plate voltage specified on the data sheets is measured across the tube only--not necessarily to ground. That is, measure at the plate and cathode pins (above any cathode resisters, etc.).
Thanks and another question....
Thanks Frank and Joel; I think I get it now.
Okay, here's another question:
Given the following conditions (RCA given operating point), what power output can I reasonably expect? Could it support the 3.5watts that the Philips spec claimed?
For the pentode section of a 6BM8:
1. V plate to cathode = 200V, Ip = 35mA
2. V grid 2 (referenced to cathode) = 200V, Ig2 = 7mA
3. cathode floated 16V to provide bias
4. 5kr OPT, 8r load
5. mu = 9.5
If I feed g2 with 13.5Vrms, I get 13.5*9.5 = 128Vrms and Vout(rms) = 128*((8/5000)^.5) = 5.13V
Okay, with Vout = 5.13 I get 5.13^2/8 = 3.3 watts rms.
Can a 6BM8 support this under these conditions? If not, I can increase the B+ up to around 300V without too much hassle (I'm using a Hammond 269JX 500VCT@60mA trafo in a fullwave configuration with SS rectification).
Assuming that those numbers look okay, I'll set the triode section for a gain of about 11 to keep from overdriving the pentode. Sound like a (good) plan?
Thanks again for all your help and understanding!
Morse
4. 5kr OPT, 8r load
5. mu = 9.5
Morse
ECL82
The tube can certainly handle this dissipation, no problem there.
If you consider a SE amp with this type I think an effective output around 2 W is more realistic.
In case you care for a couple examples you can have a look at these:
ECL82
Try to work through the diagrams and you'll probably see that the Philips datasheets are pretty useful stuff to have.😉
That is going to give you way too high a B+ with a FWB using diodes...unless you need that voltage for something else, I dont see much use for it.
Cheers,😉
ECL82
Cheers,😉
Thanks Frank;
>>>....That is going to give you way too high a B+ with a FWB using diodes....<<<
Sorry, my fault - I'm going fullwave, but not a bridge. Hmmm, I've just checked it again with PSUD II, and using anything from 75mA to 90mA idle current I'm right in the ballpark around 250VDC for raw B+. That's with a 100uF->390r->100uF filter, by the way.
Anyway, thanks again - it's great having knowledgeable people to ask!
By the way, this one's purely a "what I have on hand" type of amp - hopefully I won't have to buy anything ('cept maybe another pair of 6BM8's as spares...) for it. That's one reason for the trafo - I've got one and it looked good on paper anyway...
All the best,
Morse
All the best,
Morse
Plate Voltage Definition and Conditions
Greetings All,
My searches return this thread as the most relevant to my current conundrum. In an attempt to make my questions slightly less idiotic, I am flogging the reluctant mule of my brain through the excellent Audio Classroom articles on the AudioXpress website.
It will come as no surprise that I am confused, this time with the concept of Plate Voltage in the Voltage Amplifier article. The perplexing passage occurs at the end of page 4, and reads:
So here's what I'm wondering:
1. What is plate voltage measured with respect to? The emitter?
2. Under what condition is it measured? This is what is puzzling me, for it seems to me that, under the conditions in the quoted passage, when I = 0 there will be no voltage drop across the plate-load resistor, and the plate voltage will not be 250V, but rather the "very high B+".
So what am I missing?
Barring active cathode-loads, don't all load lines pass through the point (0 mA, B+ V)? So aren't all tubes in such circuits stressed by B+ V on their anodes at 0 current?
I've tried to be very explicit in my question, so that it will be easy to answer.
If I am diligent enough, I hope to someday understand the SYclotron circuit. 😀
Thanks for your help, and happy tweaking!
Best,
George "Enthusiastic Amateur" Ferguson
Greetings All,
"...the plate voltage here does not have the same meaning as the B+ voltage we have been working with. Here it means voltage on the plate ; it does not allow for the drop in the plate-load resistor... If the tube was operated from a very high B+ voltage, and fed through a large load resistor so as to give 250V on the plate, an amplification of 100 would be approached.
Best,
The cathode.
Static. IOW whilst idling.
I = 0 does not occur, there's always current flowing unless you interrupt the current flow. By pulling the tube, for instance.
Just imagine a class B amp and know that tubes never reach total cut-off condition, you'll realise you just can't stop current from flowing.
Hope this helps a little,😉
The cathode.
Hey Frank,
Thanks for the reply.
Okay, plate voltage is measured between the anode and cathode.
And you said:
Forgive my thickheadedness, but this I do not yet understand--for the literature I am reading seems to imply that the plate voltage limit comes into play during dynamic conditions.
Looking at page two of the "The Power Stage" article on the AudioXpress website, I see the following passage:
(continuing my question numbers, at three...)
3. My interpretation--since the grid is relatively close to ground in most circuits, and B+ is positive wrt ground, the greatest potential difference (and flashover danger) occurs when the plate reaches its most positive value, for this is when the grid-plate potential is the greatest magnitude. Correct? That makes sense to me.
4. Also known as B+, right?
5. This is because X(L) = 2PiFL, right? And because no inductor is is ideal in terms of having 0 DC reactance?
Now comes the fun part:
6.
How can the plate voltage go positive from the supply voltage? Doesn't this mean the plate voltage is swinging above B+? I don't see how this can happen.
Any guidance appreciated. Otherwise I'll just keep pondering, and will figure it out eventually.
Thanks for your patience!
Best,
George "Amateur With A Headache" Ferguson
And you said:
Static. IOW [In Other Words?] whilst idling.
[plate voltage] is specified in one of two ways: the real limitation is the maximum positive excursion, because the danger is that of flashover from a high potential difference between the plate and the grid;
but most circuit designers prefer to have a maximum working-voltage figure, which is the highest supply voltage that can be connected to the plate circuit.
In any output stage the plate-supply voltage is connected to the end or the center tap of the output-transformer primary, the plate being connected to the other end. In the quicescent or no-signal condition, the plate voltage is almost equal to the supply voltage, being reduced only by the small DC drop in the winding.
When the plate voltage changes because of an applied audio signal, the fluctuations will go positive as well as negative from this supply voltage.
6.
Best,
It does but when I said measure it so and so I meant it as a way of checking what the actual plate voltage was, to cross-check if the circuit is operating correctly if you like.
What NC is discussing are dynamic conditions that can occur while the amp is actually working.
It's been ages I read that series of articles but I get the feeling he's talking about the plate and screengrid potential flashover here.
4. Is not correct, that would actually be the highest possible plate voltage as given in the datasheet of that particular tube.
At least that's how I read it.
B+ can be as high as you like for as long as the tubes see a correct plate voltage it won't care what the actual B+ is.
5. That's just because OPTs are chokes and chokes inevitably have DC resistance, hence a voltage drop across them.
I think what NC means is that the output voltage at the plate can swing above quiescent plate voltage....
Not too sure what he means here so:
I'll see if I can find the articles, I think they were once published in SP....
It sure gets confusing especially for a poor non-american like myself...😀
Cheers, 😉
Cheers, 😉
My understanding is a Choke loaded tube can swing voltages in eccess of battery plus. (B+) The "extra" voltage comes from the energy stored in the inductence. Same principal applys for a transformer. Energy is stored in the primary inductence.
On the intuitive level, a transformer loaded tube has its plate sitting at b+ minus the dc resistance of the winding. if the transformer couldn't swing above b+, we would be left with about class b operation.
Hope this helps;
Doug
Hi Doug,
Yes, your message is very helpful, and addresses exactly the questions I am pondering. Stored energy in the transformer's E-M field--that could be just crazy enough to work!
For example, take a look at this schematic of the J.E. Labs 300B--It shows exactly the sort of situation Crowhurst, Degrove and you describe:
I'm assuming the schematic's voltages refer to the quiescent conditions you all describe. They show the output tube's plate (quiescent voltage?) at 425V, out of a B+ of 435V. Knowing that SETs operate in class A, I was at a loss to explain this situation.
But capacitors store energy in voltage, and inductors in current--yeah! So my guess is that, when the amp warms up to idling conditions, the increasing current stores energy in the inductor (and while the current changes there is probably a relatively low frequency voltage across the secondary/speakers?
Let's see, it takes an infinite current through a capacitor to create an instantaneous change in voltage across it, and an infinite voltage across an inductor to create an instantaneous change in current through it, right?
So when our idling amp receives an AC signal, it responds by changing it's anode current, and the OT responds by changing its voltage drop?
And the sign of that voltage change reverses for current increases and decreases?
Hmmm... doesn't that imply that (ignoring the DC drop across the cathode bias resistor) the plate voltage can swing from (almost) 0V to (almost) twice B+? (This part I am even less clear on 😉 )
Wow! For "simple" devices, there is a lot going on in even a basic SET!
This only increases my respect for the folks that created them.
Thanks Frank and Doug for your help. 😀
Best,
George "Headache Slightly Better" Ferguson
Best,
- Tubes / Valves
- Help! Dumb questions about a spec sheet....
