Help/Confirmation identifying a 5pin connector from a picture: which serie? (2mm pitch on pcb)
Hi
As i have been burned quite a few times thinking i know the right connector and failing (having to re-order...), i would be grateful if some could help me identifying the connector on the picture.
It is mentionned a 2mm pitch on the PCB. It connects a keyboard pcb to a usb-A cable.
Given the 2mm pitch on pcb, is it for sure a PH or a PA (refering to link ) ?
Thanks in advance
ps:
Purpose: ordering the counter connector with a cable to change the type of mechanical connection (usb-c instead of usb-a)
