Hi-
I want help choosing two midrange speakers, a sub (8") and a headunit to put in a cooler boombox. Can I just hook up 3 speakers/ subs to a 4 way head unit?
The mid range speakers (unless they have closed back) will need a separate cabinet from the sub, as the sub will pressurize the cabinet (cooler). Just use two badass 6x9s in cooler with lots of power and maybe some EQ, so no extra subwoofer is needed...?
Is this some kind of custom designed concrete cooler you have in mind, as it's hard to imagine a typical cooler being strong enough to house a sub...?
Thanks for the input. What about 3 6x9's? Whats the best 6x9 for around $25 (im only a kid so I dont have that much $$$) Also a good cheap head/ amp.
I have seen some coolers with subs on youtube though... https://www.youtube.com/watch?v=K_CB2qQPNAM
