Help Choosing
The mid range speakers (unless they have closed back) will need a separate cabinet from the sub, as the sub will pressurize the cabinet (cooler). Just use two badass 6x9s in cooler with lots of power and maybe some EQ, so no extra subwoofer is needed...?
Is this some kind of custom designed concrete cooler you have in mind, as it's hard to imagine a typical cooler being strong enough to house a sub...?
