Hi! I have been using ProAc Response 2.5 clone some yrs ago and now I am looking for tweeter drivers for a new build.
I like the sound in Scanspeak but have heard of tweeters that are better and a size larger. What do you recommend for a step up there? I am looking for a soft touch to it and clean, not to harsh.
Thanks for advices.
Thanks for advices.
did you build the clone with original D2010 tweeter
or the version Troels had on his site?
I did work with D2008 tweeter. One mean little beast.
Performs very well once the XO is right.
Ok the D2095/9300 perhaps is the way to go. I remember listening to them and they was really clean and soft. How is the "peer point" in those? The 2.5-Clone was just a big sound wall.
I am planning a complete new 3 way build. And working my way down. Would a Dayton Euro 7" be a good match?
Dayton Audio ES180-8 7" Euro Series Paper/Fiber Woofe | 295-350
I can say that i would like to have some "peer point" effect
It comes down to your capability as a designer and time and money you want to invest.
For a 3 way build D2010 is fine. It depends more on what you are asking it to do.
If you crossing it to a small 3" mid around 3khz, it's just fine and dandy.
That Dayton/Usher driver is not available. Usher 8945A and couple of other drivers can be used.
Are you looking to design and build from scratch or build a kit? Whats the budget? How are your woodworking skills?
Scan makes a lot of drivers and there are a lot of possibilities.
Thanks for the graph
concerning the Dayton 7" it seems like a woofer more than a midrange
http://www.audioalchemy.ro/difuzoare/dayton/ES1808.pdf
And the clone driver (mid-woofer)
http://www.scan-speak.dk/datasheet/pdf/18w-8535-00.pdf
Then use a real midrange..
IF you like a low crossover point for the tweeter then here is a grouping:
New Transducer Labs N26 Ceramic Tweeter - Page 2
- Help choosing Scanspeak
