If it was me; Scanspeak Discovery 10F/8424G 4" Midrange 8 ohm
The Madisound Speaker Store
Crossover points around 300Hz and 3k Hz, and if was for me, I'd go active just like the speakers playing Eurythmics now.
Abs
Abs
That is a nice choice of midrange by Absconditus. This is how you do a passive Scanspeak three way using something similar:
ScanSpeak-3W-Discovery
Although it uses neither of your two drivers, you might say it uses more appropriate ones.
Your ScanSpeak Classic 21W/8555-00 is going to need some complex filtering to deal with the peak at 3.5kHz. You see, his one is easier.
Troels' choice of a ring radiator tweeter rather than a soft dome is also something a lot of people would approve. So now you understand the design choices better, I hope. Good luck, it's going to sound very good regardless.
Ok, with the drivers you have chosen so far, you want to stay in the upper end of sound quality. In no particular order:
scanspeak-15w/8530k-00 +/- 350Hz & about 2800Hz
satori-mw16p +/- 300Hz & about 2000Hz
BG, Neo10 +/- 500Hz & about 3000Hz
BG, Neo8-S +/- 600Hz & +/- 3500Hz
Vifa NE149W-08 xo about same as SS above
Vifa NE180W-08 xo about the same as Sarori above
Others can add their own preferences. You might also find these threads helpful:
What mid and tweeter for high end 3-way
Big price drop on the SB Satori Woofer
