Hi Folks,
hope you can help me!
Some time ago i bought Glasshouse attenuator mono from Hificollective, which is the Elma A47.
I opted for the 0,25w carbon takman and Zfoil.
they came pre installed, however i do not understand why the 'in' is not used..
So this is how it is hooked up:
ground: to ground
out: a z foil resistor and the output signal.
now the part i find odd:
on the out is also the z foil resistor and then the input.
So the input signal goes through the z foil to the output of the A47 and the output (attenuated) is also on the output...
is this because of some reason? a mod e.g.?
got me baffled, strange thing is, it does work this way.
help and or clarification would be much appreciated!!!
Verzonden vanaf mijn iPhone met Tapatalk
ground: to ground
So i.e. only the out is used for signal.. i still find this strange, espescially as it seems to work...
What is going on here... 😉
