Help About Morel mdt29 and mw166?
I find one.
Hi!
XO is "cross over".
The MW166 has a nasty peak in the midrange. The Xover used in the Morelline uses a trick: an impedance equaliser (R+C+L // MW166) that when conbined with the coil makes notch filter!
The result a quasi perfect slope (I cannot remember 12 or 18dB/octave) with only a coil in serie with the MW166. You can use lower cost compoments for the "notch filter".
The drawback is that the redge frequency is a bit low so you'll have to make at least a 12dB/oct Xover for the tweeter to maintain power handling and low THD.
Anyway I do hope you have a measurement device unless you'll go into trouble to tune thos complex Xover...
You are Chinese! I often travel to Shenzen & Ningbo....
If I can help you ....
@+ Mickael
