Help a total tube amp newbie find a super simple design...
nerd of nerds said:
Any chance that you'd provide me with a schematic 😉
I was just throwing the idea out there of using a wall wart...i figured it probably wouldn't work, but i figured, what the heck...
Thanks for all of your help!
Look here at the B+ supply used in "El Cheapo". That supply is good for 200 mA. of DC. For a lesser draw, a smaller 1:1 isolation trafo is in order. The 1:1 trafo should be rated for an AC RMS draw 4X the DC B+ draw.
hey nerd of nerds!
I built that 'strange' 12AX7 circuit.....!
I wanted to build a cheap battery operated amp, it works gives way less than a watt...
HV is derived from an astable multivibrator...
For stereo you could do about 4 hours of listening with a scooter-battery (incl. heaters)
i used an opel bobine as opt!!
it sounded quite allright but nothing fancy...an autoformer is way from ideal!!!!!
never thought i'd see that one again....!
greetz !
