Help a noob fix a ZV9
sts9fan said:
The Jfet on the working side is reading constant 4.3vdc while the non-working is 5.0vdc. Is that significant?
You need to take a photo of the upside and the downside of the project.
This way we have a chance to see if you have done something wrong. Next you can take a schematic, and post the measured voltages.
If you want to go try fix this yourself, compare the measurements of the good and the bad channel, and see where something is significantly different.
I personally would not take much notice of 0.7V difference, between a working channel, and a bad channel.
Magura 🙂
sts9fan said:
Shockingly there was a blob of solder where it did not belong.
Actually this is not shocking at all 😉
I have been helping many "first projects" over the years.
When such are not working, 99% of the cases, it is due to one of these reasons:
1) Component misplaced, or turned 180 degrees.
2) A solder "blob" .
3) A solder whisker hiding in the flux residue.
4) A bad solder joint.
5) Wrong polarity of external connections
So, it's a rare newbe problem, that is not fixed by the above checklist.
Magura 🙂
