Help! 2A3 SET quit after hot restart
I have a home-built 2A3 SET amplifier. The circuit is very simple. Two stages capacitor coupled with AC filament heating. The 2A3 are EH gold pin.
The amp runs fine except if I shut it off and turn it back on while still "hot". There is no sound. I measured the 2A3 and the plate voltages are around 400V and grid voltages are around 300V and the heater around 40V. I checked the coupling capacitors. There is no leak. The plate voltages of the previous stage are around 170V.
It sometimes refused to start up until I moved tubes around a few times. Can someone help to provide possible root causes? The 2A3 grid leak resistor values are 499K. Could this be a problem?
Can you explain how do you measure these voltages? They look a bit odd...
A 2A3 doesn't have a heater but a 2.5V filament. Is 40V the drop through the cathode resistor?
How do you measure 300V on the grid? What's the reference terminal?
Please post a schematic of your amp so we can get more information and ask for specific measurements.
M. Gregg
