This is my pre amp :
With a 100k pot going out after the 470uf cap .
Yes , there is sound , but my strat IS acoustically louder then it .
And with this power amp :
http://www.futurekit.com/2009/manual/future/eng/PDF_FK6/FK604E-2.pdf
It's hooked up to a 12Wrms 4ohm load .
But when i tried it with a line output ... the preamp pot smokes and arcs .
Does the FUTURE KIT work by itself? Which pot is it that arc's? is it the one on the FUTURE KIT? You will need to give us a more detailed discription befor we can understand.
It does , if i just use the line in from something else , but it won't work as a guitar amp by itself , so i made this preamp , the 100k on the output of the preamp is smoking .
1 is to ground 2 is output 3 is input .
Ok well I have looked at the data sheet for the LM386 and it is able to put out 350 milli watts of power, so it may be that you are dumping that into the pot. You have a blocking capacitor between pin 5 and the pot so that means its not a DC problem, asuming it is wired just like the diagram. Really, the right answer is that you shouldnt use the LM386 as a pre-amp. You can do what you need with an op amp. It should be one with a high input impeadance to match your guitar (say 500K to 1M ohm) and the gain will be something on the order of X10. or mabe a little more. Look around for a Op amp pre-amp design. The parts should be realllllllly cheap.
You know what, on second thought this is probally a incorrect connection. double check your wiring.
It's been checked , with magnifiying glasses , nothing is incorrect .
Sorry, that's not a preamp, it's a small power amp - and you don't put a 100K potentiometer on the output of a power amp, even a small one.
Trying to feed a speaker from it means the pot has to be fully at one end, or VERY, VERY close to it. This means it burns the pot out.
The pot needs to be at the input of the little power amp, not the output - but what's wrong with the pot already in your guitar?.
it's feeding the power amp , who has a input impedance of 50k
Exactly, so you don't need another one.
The issue is about overdriving the power amp ...
I'm still confused about exactly what you're trying to do?.
The circuit posted above is a power amp, NOT a preamp, it's designed to be fed directly from a guitar (using the volume control in the guitar) and to directly feed a small speaker from the output. It's just a couple of hundred milliwatts, for a tiny practice amp.
Assuming you're wanting to use it as a (fairly poor quality) preamp then you can fit a potentiometer to the output (use a 10K pot), with the slider feeding to another power amp. You must NOT connect a speaker to the output of this pot or you will short it out and burn it out, as you already have.
I DID not connect to a speaker , just to a power amp .
That's just a diagram drawn up from a instructable .
Assuming that's what you did?, then you must have connected the pot incorrectly, shorting the output of the LM385 to ground. That's the only possibility, as there's no possible way the pot could burnout if connected correctly.
Can you post a diagram of how you connected it?.
Fair enough ?
Oops , output is on 2 , input is on 3 .
Yes, you have input and output wired the wrong way round, the slider (middle pin) is the output feeding the power amplifier.
As i written up there 2 is output , 3 is input .
- Live Sound
- Instruments and Amps
- Hello People I have Pot Arcing and Soft input issues .
