I am planning to build a projector similar to lumenlab's guide but mine will be vertical to save some space.
I am in the process of looking for a suitable 15" LCD and was thinking about Envision EN-5400 15" LCD Monitor from staples as I can get it locally and it will cost about $175.
Would I have problem with its flat cable?
What are some known LCDs with fully compatible flat cable that is less than $180 ?
I already have a triplet lens from a slide projector and was thinking I can probably use that.
thanx~!
thanx~!
