Helix HXA400 MKII stuck in "protect"
Hi guys,
The amplifier stuck in Orange protect light, which stands for 'speaker wires are shorted to ground'.
They obviously aren't 🙂
SG2525A
Pin1: 2.56v
Pin2: 5.14v
Pin3: 0.02v
Pin4: 0.68v
Pin5: 2.05v
Pin6: 3.66v
Pin7: 1.97v
Pin8: 4.87v
Pin9: 6.01v
Pin10: 0.76v
Pin11: 0.068v
Pin12: GND
Pin13: 8.3v
Pin14: 0.12v
Pin15: 8.47v
Pin16: 5,15v
LM324N
Pin1: 9.95v
Pin2: 5.94v
Pin3: 10.31v
Pin4: 11.20v
Pin5: 1.36v
Pin6: 5.93v
Pin7: 0.05v
Pin8: 9.45v
Pin9: 0.12v
Pin10: 9.0v
Pin11: GND
Pin12: 9.02v (descending when probing)
Pin13: 8.92v
Pin14: 9.79v
Hopefully this image gives a better idea of the amp.
Two years of silence. Did you ever solve your problem?
Found this thread, as I am in almost same spot.
Have a HXA 400, which shuts down two second after audio comes through.
Main power applied, - power on by energize (the small wire). Turns on and then goes into protection mode (red LEDs) and 7-8 volts on the output.
Like yours?
