heatsinks
This was one ugly heatsink!
Well, it could work depending on how much cooling you need.
This seems to be made for cooling CPUs, and it comes with a fan. When it is running at 12V the thermal resistance is 0,28°C/W, which means that the temperture rise is about 0,28° * 100W = 28°C when dissipating 100W into the heatsink. With an ambient temperature of 25°C the heatsink temperature will be 28°C + 25°C = 53° probably a little higher, though.
But this uses a fan too help cooling the heatsink, which I hate because it's always so noisy. And there seems to be very little space for mounting the power transistors. And don't you think it's very ugly? I do.
I would definity look for another heatsink, a normal one if you are planning to use it with an amp.
Check for example
http://www.fischerelektronik.de
[Edited by Freddie on 08-24-2001 at 03:48 AM]
