I need a little heatsink for a TO3 transistor and found this one a Wakefield THM 6051 but somehow can't find it in the current catalog. Does any here know the
thermal rating of the THM 6051.
It's a stamped sink, so on each bolt use a washer on the bottom of the sink, then the nut,
and torque it down good. Then put the ends of the bolts through the pcb and fasten the
TO-3/sink assembly to the board with two more washers and nuts, before soldering the pins.
This way there's some air space under the sink for ventilation.
