Heatsink Finishing
In this case I believe the OP is using these heat sinks on a sissysitR3 which also means he has 2 devices on each heatsink that has different thermal output. The mosfet is doing most of the work while the sit is coasting. I am also building sissysitR3 as well and want to get it right without buying more heatsink than I need between freight and material cost ( heatsink USA) it jumps pretty quickly.
Bill
