Heatsink dilemma, reduce Vcc or Iq
due to a the heatsinks i bought being mislabeled.... Grrr.
i've got working PLH Monoblocks that run just a bit too warm.
they currently run ~40v @2A each channel.
the heatsinks are 2x 0.7 deg/W each monoblock
this gives 28degrees C above ambient, which might be ok if i was back in the UK, but i'm working in China where the ambient with AC is ~30degrees.
currently i've blue-tacked fans on top, but this has low WAF and is a little noisy,
options are reduce Vcc a couple of volts, or reduce Bias.
in the PSU i have CRCRCRC the R's are currently 0.1 or 0.05 i could easily up the first R to 1-2R to drop a few volts,
or would i be better to drop Bias by a similar amount?
advice appreciated
As long as your heatsinks are below 60°C, there is no risk of skin burn.
This is why 60°C is the maximum allowable temperature that something that can be touched may reach.
For the components themselves, my fellows did already answered.
BTW, power supply current is constant in A class amps, so raising R is not a problem, except for the R itself (heat). But again, no need to do that.
i'm thinking about 10deg less heat, so around 12w
the amps reach 60+ deg. depending on ambient.
i fitted 60 or maybe 70 degree thermal switches inside, and these tripped without the fans. i need to check if they were 60 or 70.
i'd rather not run the amps so hot, it's not great for component life.
as mist speakers are nearer 4 ohm than 8 in reality, i guess losing a couple of volts would be best.
Depends on if you need 40V rails for your speaker load.
A slightly naughty option is to wind on extra windings onto the secondaries in the opposite direction to drop V, but that adds heat, which is already a problem for you....
.................options are reduce Vcc a couple of volts, or reduce Bias.
or would i be better to drop Bias by a similar amount?............
you could add a small amout of resistance BEFORE the smoothing bank.
You already have an rCRCRCRC supply. The little r is the resistance before the smoothing bank.
Just increase that with an added R of maybe 0r5
That 0r5 + r will directly impact on the effect of the first C since it is a filter in it's own right.
But it ALSO increases the source impedance seen by the second anf third and fourth stage capacitors. It increases the filter effect of ALL 4 stages.
You can also increase the final C to CC to remove the objection made by Audiosan
Reducing voltage by up the R in the PSU is not a good idea. That will kill dynamics.
he considered the wrong end of the smoothing bank. It's the last C that determines the transient current fed to meet the speaker demand, not the first or second r/R.
