WARNING: Tube/Valve amplifiers use potentially LETHAL HIGH VOLTAGES.
The Heathkit AA-151 is an EL84 based integrated. You guys think it's worth $150 for the Iron, etc., to try my first amp build of a new EL84 or SV83 based amp design?
My own opinion - I'd put the $150 into Hammond transformers. If I were using parts from an existing amp, it would be one that isn't restorable, and I'm sure it wouldn't be $150.
