Heat to board
3 by 5 inch
hello.
if you want to fix transistors or opamps you will drill some holes in the heatsink i think.
so you may fix the heatsink with screws on the board.perhaps you can use self tapping (or self drilling) screws,or use a steel cavity fixing for the screws..............
annother method is fixing with glue but i do not like it very much because the glue " gets dry" and crumbles after a longer time.......
greetings...........
I wouldn't use self-tapping... The heads can torque off the shaft and then you've got yourself a difficult-to-remove problem on your lovely heatsink. Run down to a tool shop and buy a drill bit, corresponding tap and a tapping tool (if you don't have a good-quality powerdrill with clutch).
The upside to this investment is that the tap will more than likely prove itself useful time and again.
