Does anyone have any insights into the linearity of headphone sensitivity as power is reduced? For example, given headphones with a sensitivity of 87db SPL at 1mW, the power that would output 0dB SPL is 0.185pW.
But surely the headphone actuators would stop moving long before that on the grounds that a minimum power would need to be applied to overcome the inertia of the actuator? So I am guessing that sensitivity becomes non-linear at low power levels.
Regards...
Regards...
...a minimum power would need to be applied to overcome the inertia of the actuator?...
No.
You are thinking of friction, static friction.
If sensitivity changed with level that would be Distortion. Yes, there is distortion, but at HIGH levels not usually LOW levels.
No I'm not. I'm thinking of inertia. Yes, there will be friction due to the stiffness of the diaphragm but that effect is linear so I'm not concerned with that.
At any power level, sensitivity changes with frequency - look at any specification sheet - so you will get distortion for a real-life audio signal. But sensitivity is measured at a single frequency so variation over frequency, and any distortion that accrues, is irrelevant. But I'm not concerned with frequency, I'm concerned with power level. Similarly, if sensitivity changes with power level distortion equally does not apply.
