Hello all.
This is my first post here.
I am looking to put a headphone out circuit on my DIY dummy load/attenuator box(Lpad). I have tried the basic voltage divider circuit but of coarse the sound is horrible. I think a cut somewhere in the 6K frequency area is needed but I'm not sure. Does any one have a schematic of a simple headphone out circuit that will provide a reasonable speaker emulation sound?
Thanks in advance
Thanks in advance
Thanks dsavitsk for the links. There is some great info there, but they all seem to be active headphone amplifiers , I was hoping to find a circuit for a passive filter network that would somewhat emulate a speaker in the phones. The input to this circuit will be the output from a tube guitar amp that is fed to a passive Lpad attenuator capable of attenuating to a dummy load(no speaker output) So i guess this circuit would basically be a voltage divider followed by some kind of tone shaping network to reduce the mid to high end frequency hump at which I would guess to be around 6K. I know speaker emulation is a hard thing to do without modeling,but I am just looking for a basic circuit that sounds OK without a lot of components and is passive. Look forward to any responses.
US2400, not quite sure if I understand you, but take a look here:
http://sound.westhost.com/project100.htm
http://sound.westhost.com/projects-1a.htm
Hi US2400,
maybe I am wrong, but if I understand you right, you are mainly looking for a speaker-emulator circuit (you already worked out the attenuation with a voltage divider)?
I have a Marshall 6100 (anniversary model) which has something quite close to that. It's a balanced output with speaker emulation, so you don't need mics in front of your cabinet for live performances.
Have a look at the schematic. Maybe you get inspired by this.
The speaker emulation is on the schematic for the MIDI control. But I guess you also need to look at the power amp section where the connectors go to.
http://www.drtube.com/marshall.htm#AN30
I know this is not exactly what you are looking for (a bit too complicated, active components etc) but maybe its close enough...
Martin
Martin
Thanks Gordy for your response. That is basically what I,m looking for.That circuit is close to what I used and the sound is not great,but I will try some of the resistor versions offered in the table
Thanks Bayermar Yes I'm looking for a speaker-emulator circuit but for headphones. I think your amp offers a line out circuit for patching into a board or recording device.
Basically what I am looking for is half decent sounding headphone circuit that can be installed at the output of a tube amp.
