Headphone Guitar amp with mp3 input
I missed when things flipped from non-invert, to invert and back again so the input resistor on the inverting version was needed.
C3 should be flipped around (or better yet, use bi-polar caps on all the inputs).
I'm not following; with R7 and R8 in the circuit, what's the need for R1 and R2?
Look at nigelwright7557's post a few posts up for the reason behind c3 being in the configuration that it is. I may use bi-polar caps for those before it's over anyways, but I have a lot of polarized smd caps that I want to use up so I don't know yet.
I tried the circuit without R1 and R2 and it lost over half of it's volume. I can't remove them. I don't know about R7 and R8. I haven't tried removing them yet.
Here is a pic of my amp almost completed. It works great and sounds really good. I made it so that a 9v battery will sit right down in there and fit perfectly in the 2"x3" enclosure. Thanks for all the help and advice. I will post some completed pics when I get the last stereo jack that I am missing and clean some of the flux off the board.
Here is the final schematic.
Its nice when something comes together and works well.
Whats your next project ?
I am in the process of designing a midi light box for electronic drums. It is based around the Arduino and basically flashes a light each time a drum is struck. These can be mains lighting or LEDs inside of each drum or whatever else you want to light up. The hardware is finished and I have teamed up with a programmer to do the software end of it. The final product will have a 16x2 lcd display and a five button input for changing the color, duration and midi note.
Eventually we will taylor it to work with any midi instrument. Here is a pic of the first prototype that I made.
