Here is a thread about a headphone amp.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=90324&perpage=10&pagenumber=1
Re Headfphone Amplifier Kit
Silicon Chip magazine recently pulished a design for a very high quality headphone amplifier kit and a suitable voltage regulator board. The unit is able to drive headphones from 8 ohm to 600ohm. (minor component changes for high or low impedance phones.) It is also designed to drive 2 pairs of headphones at a time. The constructor would need to be able to safely build it in a suitable plastic case containing a 15-0-15VAC 20VA toroidal transformer , mains switch and sockets etc, as well as a volume control . I am using such a unit with my X-FI PC sound card.
Jaycar Electronics sells both kits for<AU$40 (KC5417 and KC5418)
I had to fit a banana plug connected to the amps mains earth , to plug in a lead connected to the PC metalwork ,to kill an earth hum
www.jaycar.com.au
SandyK
www.jaycar.com.au
SandyK
HeadWize is more of the repository of diy headphone amplifier knowledge
http://headwize.com/projects/index.htm
and the DIY forum there has some active projects that don’t have project articles yet
http://headwize.com/ubb/forumdisplay.php?fnum=3
most head-fi DIY forum builds are based on the Headwize projects (and several are built and sold as commercial products )
another good site for diy headphone amp info
http://tangentsoft.net/audio/
re Headwize
I have seen many of those designs, and haven't been overly excited by most of them. IMHO, the recent Silicon Chip design would have better performance than most of them, and is also capable of driving 2 sets of headphones at once. It can also be optimised for the low impedance OR higher impedance types, and gives a reasonable amount of protection to the wearer of the headphones as far as potententially ear damaging levels are concerned. The measured specifications are also very good by today's standards.
The big advantage is the price of the kit which is just under $30 for the Headphone Amp kit only. Both kits are about AU$48 (not AU$40 as I said earlier) The kits are also capable of even higher SQ with changes of the opamps and O/P devices.
Hopefully, there is a (poor) copy of the schematic attached.
SandyK
SandyK
If you're just looking for something affordable, easy to build, and still sounds quite good (with a lot of options to upgrade), I had started a small thread, again based on a design found off the web....
http://www.diyaudio.com/forums/showthread.php?s=&threadid=92299
Great thing is, you still have cash in the end to try using different opamps.
I had trouble keeping to 120KB attachment limit. If you care to email me, I will send a decent size schematic and photo.
SandyK
alexkethel@optusnet.com.au
SandyK
What format is the picture? If you convert to GIF (ie. by using MS Paint) there is usually no problem with file size. Howver, that works best with original drawings made on a computer. Scanned pictures might be problematic.
BTW, I wonder why they took the effort to make the buffer so complicated, with dual CCSs, and still not changed two diodes to transistors to get a diamond buffer instead?
Let's try a TPA6120
Hello,
If you're not against SMD chips, you can try a TPA6120 chip. Several threads talk about it on this board.
Or hydrid, solid-state or tube-based design. http://www.headphoneamp.co.kr/ftp/sijosae/Gallery/
Thanks,
Max
Hello,
Thanks,
Max
Headphone Amplifier (circuit needed)
2SA 1939 should have read 2SA1930
BTW, Silicon Chip magazine is a world class electronics magazine. I have bought every single issue since it's inception.
If anyone is interested, the May 2007 issue contains the first part of a 20W Class A project. They claim it has the lowest distortion of any design ever published. I am using a modified version of their original 15W Class A design.
Us Aussies are very proud of Silicon Chip magazine !
SandyK
SandyK
Re: Headphone Amplifier (circuit needed)
How did you modify your's?
I up'd the volt and bias on mine long ago, still works
sweet sounding amp, up'd power adds more too the lower end.
as for the headphone amp see
http://headwize.com/ubb/showpage.php?fnum=3&tid=6605&fpage=1
much better than the SC one
also if your used SC preamp try AD's in place of the opa2134's
allan
SandyK
allan
I see some possible leads at
http://www.amb.org/audio/beta22/
I have the M3 MMM M^3
http://www.amb.org/audio/mmm/
Wondering how the B22 compares with the "Cavalli-Kan Kumisa III" ??
And if either is much better than the M3
re Headphone Amplifier (circuit needed)
Re Class A Amplifier changes
Among other things, I used dual regulated power supplies and a shielded Toroidal transformer with dual windings, as well as 2 bride rectifiers. I replaced the TIP41/TIP42 series pass transistors in the REg. PSUs with the faster MJE15030/MJE15031 as well. I also used the wider bandwidth 1302/3281 in place of the MJL devices.There were numerous other changes too.
SandyK
Allan
I have sent you an email. So you may have to check your spam filter.
SandyK
Allan
- Headphone Systems
- Headphone Amplifier ( Circuit needed)
